H1 problem
11 years 9 months before #44830 by manual-mecanica
Manual-Mecanica response on the problem with an H1
Hello, I have been with the car today and I have changed the thermostat and if I still think it is the ostrured radiator because it is cold as the water does not circulate, open some product to clean it.
11 years 9 months before #44832 by manual-mecanica
Hello ago, if the thermostat is fine, do you say that it keeps throwing through the boat? It is difficult for the radiator to be obstructed, remove the input and exit sleeves from this and "blow through it. I suppose the box of the plug is fine .. you can have a problem with the Board of the Bill, I do not think it has any fissure ...
11 years 9 months before #44833 by manual-mecanica
I suppose that when you have put the thermostat you have had it started until the fan has lit, because until this happens, it takes a while ... greetings !!
11 years 9 months before - 11 years 9 months before #44843 by manual-mecanica
greetings
Last edition: 11 years 9 months before by .
11 years 9 months before #44844 by manual-mecanica
H1 the fan is always running, when the water is heated is when it passes out and when I stop
