H1 problem
11 years 9 months before #44815 by manual-mecanica
Problem with an H1 posted by manual-mecanica
Hello, I have a Hyundai H1 and my problem is that the radiator water is emptied by the garage over where the car is filled and heated, someone knows to tell me why this occurs.
11 years 9 months before #44817 by manual-mecanica
Manual-Mecanica response on the problem with an H1
Hello ago, they can be several things:
1-That the thermostat butt does not open, because it is broken.
2-That the Board of Curate is burned and pass by the cylinders to the Refigure Circuit.
3-That the plug is in poor condition and escapes by the Board.
Check these points.
11 years 9 months before #44818 by manual-mecanica
Thank you very much Ismael, I will look at the thermostat that I think is that.
11 years 9 months before #44820 by manual-mecanica
You forget the radiated covered, the bisco in poor condition. But usually H1 is the thermostat if clear.
11 years 9 months before #44825 by manual-mecanica
And it is true what Kikemec says, the radiator can have obstruction, but it gives me that it is doing the thermostat, it is also true that if the temperature rises a lot for not igniting the fan, (fuse, reluct, or burned engine of the fan), the pressure is so high, that it relieves by the expansion vessel. Surely everything comes from thermostat. Greetings!!
