Skoda Octavia 1.9 Tdi
11 years 7 months before #44601 by manual-mecanica
Skoda Octavia 1.9 TDI published by Manual-Mecanica
Hello for someone who has changed distribution in this car, according to self -destroy
11 years 7 months before #44605 by manual-mecanica
Manual-Mecanica Response on the Skoda Octavia 1.9 TDI
Hi Berny 00, precaution with the draft, whenever you can, you have to use the draft tools, then "move" as I have read more than one ... and you will not see how to get it the same. This is only advice. greetings!
11 years 7 months before #44606 by manual-mecanica
If Ismael already knows but my question in which Autodata tells you to get the cam pule that has a conic seat and yet there are those who tell me in electromechanical forums that can be traveled without taking it out
11 years 7 months before #44608 by manual-mecanica
It was just a "advice" apology if you have offended, there are many ways to do things, or understand them. Greetings
11 years 7 months before #44611 by manual-mecanica
In the end I have not answered your question, to see if it is what you wanted to know: the pulley must be loosen up in case, since you make the distribution, you make sure that it has not varied the draft of this, positioning a rule of adjustment at the end of the tree and averaging the rule in the extended ones (which is centered). The engine is going well, because you do not check it and nothing happens, but theirs would be to look at the famous crankshaft key of this engine, because they say it is "goes". Check does not cost so much once in work. HAPPY YEAR TO YOU ALSO !!
