My lancer 1.5 4G15 engine loses strength in climbs.
11 years 9 months before #45011 by manual-mecanica
Manual-Mecanica response on the topic my lancer 1.5 4G15 engine loses strength in increases.
Hi Ismael and Miguel ... I tell you that a while ago, as two months or so before the failure in question, my car took my car to the mechanic that reviewed it and leaving there the coil was damaged according to the ... something that seemed strange but still bought it ... when I arrived at the workshop I had the disarmed distributor and I trust that I knew what I was doing, I came to assemble my problems. Now the matter is that I stayed the thorn if I had armed it well ... so that a few days ago the distributor disassembled, and when I opened it, the first thing I realized was that the rotor's tip was burned and when taking out the rest of the components I had as water with oil inside, I cleaned all that, we arise with great care I put my cables in the correct ignition order and that was the end of my problem. good.
To you. Thank you very much for being attentive and collaborating with me, my greetings and respect.
Angel Mendoza
11 years 9 months before #45013 by manual-mecanica
Hi Amenyaro, thanks to you for commenting on the solution, it is confused by telling me that this made it in slopes of 20 or 30 ... I thought of a overflow gasoline ...
well, recommend that you look to see where I get dirt, so that it does not happen to you again (some retain axis, or ring ..) Greetings !!!
