Citroen C3 does not start
11 years 10 months before #44475 by manual-mecanica
Citroen C3 does not start published by Manual-Mecanica
Hello everyone, I got a C3 gasoline 1.4 of 2006 in the crane. I just arrived at the key and the starter engine whispers but does not start, I will eat and in the afternoon it starts. I put it to the workshop and already dead only the starter engine, all the board lights.
I check the elongated coil block in continuity and I do not get any reading <- Will it be the culprit?
I check the cable that goes to the coils a tip of the test to a pin and the other to mass I start and only reaches 0.06volts in each pin <- according to self-destroying must arrive 11-14V.
I take out the collector I try it by passing a piece of fast metal ahead and the Tester marks signal <-Ok
continuity of the ventor cable A well, continuity of the coil cable to centralite well.
The diagnostic machine does not recognize the car.
Now I think, if I get a signal to the UCE and it does not take me voltage to the connector of the coil <- the UCE will be bad or you know something that intervenes so that the power switchboard.
I don't see impact sensor and now you contact and the fan gets butt. Cold temperature
11 years 10 months before - 11 years 10 months before #44477 by manual-mecanica
Manual-Mecanica response on the Citroen C3 topic does not start
Hello . kind regards.
Last edition: 11 years 10 months before by .
11 years 10 months before #44479 by manual-mecanica
Hello, is the battery full load? Try another, apart from this, is the injection reverse well fed? When you stop, do you still have this output?, I would start with there, then to what fellow Fiat147 says. greetings!
11 years 10 months before #44480 by manual-mecanica
Another that I forgot is the fan ... one of two, or went crazy the ECU, or to see why the electro -seventh circuit closes, and the temperature probe?
11 years 10 months before #44483 by manual-mecanica
Hello again, I emit my doubts, you create me more hehehehe.
Let's centers: I have a braided cable (Cambus) of Bolante Bolante crankshaft to direct switchboard. and a switchboard cable to El Blobinas.
The collector sends signal to the OK switchboard and the switchboard should send 12V to coil so that the coil amplifies 18.000vy has a spark.
My problem does not get anything.
All the fuses are proven, the only thing that does not know is if there is something that is blocking the switchboard or the switchboard is broken.
I will see if I download an electrical diagrams manual and look if there is something that blocks the switchboard.
