Hi Wal7er, P0300 Random Misfire detected or random ignition failure. I mean one or more cylinders suffer ignition failure detectable by the ECU or ECU detects that there is misfire or ignition failure but cannot determine alone which or which cylinders fail. The ECU Motor through CKP and CMP signals This produces a small, pro quantifiable defection of the CKP signal (crankshaft position) or missing or combustion failure. If the Misfire occurs in cylinder NO 2 and the ECU has CMP (camshaft position) can isolate the failure in the cylinder that occurs and should generate another P0302 code (MISFIRE CYLINDER 2).
 When the ECU Motor detects combustion failure P0300 increases the sensitivity of the cylinder monitoring due to the detected MISFIRE cylinder (Misfire Counters) or combustion failure counters and displays the cylinder by cylinder. This is very important to be able to isolate the failure. EJ Misfire Counters Cyl 2 is 700 and the rest approximately in 30, review conditions that can generate MISFIRE in that cylinder 2 (Injection, ignition, compression). On the other hand, if the combustion fault counters (Misfire Counters) are approximately 700 all, look operation, this serves to see if any of this data is wrong and to recreate the especially loading conditions in which the code occurs.
