Megane 1,900 80cv pump
11 years 11 months before #44453 by manual-mecanica
MEGANE 1.900 80CV Injector Pump Published by Manual-Mecanica
Hello, I would like to know if someone from the forum could help me with the issue of the injection pump. It is a 2001 Renault Megane Motor: 1900cc 80cv. The fact is that it is very difficult for him to start even sometimes, he does not start just by pushing it, when I get it out of the release it is very low and unstable and Abecean stops, in motion the car has lost a: S lot beforehand thanks for the answers you put.
11 years 11 months before #44454 by manual-mecanica
Manual-Mecanica response on the topic MEGANE 1,900 80CV PUMP
Hi Xtreme23. Make sure the problem is bomb, because I am tired of seeing how in almost all the workshops go to the or more expensive ... because in a case equal to yours, the thing was from the crankshaft collector (it is screwed into the clutch bell in the megane) it limits and measures with the polyym its resistance that must be about 580 ohms more less, move the cable when measure piece is about about 80 euros, try and you will tell us. luck!!
11 years 11 months before #44493 by manual-mecanica
Proba with the RPM of the RPM of the crankshaft but is a problem of set -up or the sensor that the injected pump has incorporated
11 years 11 months before #44513 by manual-mecanica
Hi Xtreme23. I am a firefighter and I dedicate myself to repair them and I think that I can help you. I would like it to tell me that pump model carries if it is mechanical or if it is electronic
11 years 11 months before #44514 by manual-mecanica
And if it's Bosch or Delphi
