Help with a CLIO 97
11 years 10 months before #44324 by manual-mecanica
Help with a CLIO 97 published by Manual-Mecanica
I have a CLIO 97 and what happens to me is that I was standing at a traffic light and when I want to put the first one, the reverse enters. Without using that lock that has it I have no touched at all and enter the reverse, how can it be solved? :) :) :)
11 years 10 months before #44326 by manual-mecanica
Manual-Mecanica response on the subject helps with a CLIO 97
Hi Pablo1975 ", it seems to me that the problem is on the change lever, lifts the bellows to look that no tab and the lock has been caught, also look at the adjustment of the change, disassemble the protector from under the body to see that there is no flange, spent any plastic caps ... greetings.
11 years 10 months before #44414 by manual-mecanica
Pablo:
It is very common in the Clio, that the obstacles of the gear lever are worn (if it is a 1997 model it is natural that they have worn out).
The repairs of that lever are achieved, they are not at all expensive, and any mechanic can replace them.
Luck !
