Renault Megan Entrum Pedal or Cable
11 years 10 months before #44289 by manual-mecanica
by Manual-Mecanica Pedal or Ending Cable
I wanted to see if someone could help me I have the pedal of the loose intoxication and the marches do not enter, what can it be?
11 years 10 months before #44297 by manual-mecanica
Manual-Mecanica Answer on the pedal or drunk cable renault megan
Hello, look at that particular car has a very bad clutch system ... You must look below where the clutch pedal is first if the piola cut, if not the pedal itself is where it hooks this, it has a plastic piece as a zipper that fits alone according to the wear that has both press and clutch disc. Usually this piece breaks and there the problem, or buy it or simply repairs it ... luck
11 years 10 months before #44300 by manual-mecanica
Thank you,, I will look good if I see anything I hope it is not the intoxication and that it is a little piece or the cable ....
11 years 10 months before #44303 by manual-mecanica
The cable was almost certain, check the partner, tell us how you are doing, cordial greetings. :)
11 years 10 months before #44334 by manual-mecanica
I already took it out and it seems that it goes to the brake fluid also hooked whatever the cable and the pedal piece is well or not ...
