Tata indicates short circuit
11 years 10 months before #44240 by manual-mecanica
Tata indicates short circuit published by Manual-Mecanica
Hello friends I expose my problem in case someone can answer me, it turns out that the other day, starting another car with some tweezers together without realizing the two poles and provoking a short circuit in my total car that has run out of electricity without nigun
11 years 10 months before #44253 by manual-mecanica
Manual-Mecanica response on the topic Tata indicates short circuit
Start reviewing the fuses especially those of power, the alternator diodes could have jumped too and even the ECU has been damaged, tell us how you are doing. :)
11 years 4 months before #46520 by manual-mecanica
You tried to put another battery, with enough service current, or start; Well, the witnesses of the control picture must illuminate, since the fuses are not cut, another check option is to disconnect, before trying to start the engine, the alternator connection, cable + of greater section, it is usually red or brown, I do not remember the color, but it is a thickness
