Seat Ibiza 1.4 60 hp year 2000
11 years 11 months before #44156 by manual-mecanica
Seat Ibiza 1.4 60 hp year 2000 published by Manual-Mecanica
Oscillations in the temperature indicator and if it is related to the occasional hot start difficulty. Cold starts perfectly
11 years 11 months before #44162 by manual-mecanica
Manual-Mecanica Answer on the Seat Ibiza theme 1.4 60 hp year 2000
Hi Jcerdan1, in the water box, there are 2 probes, 1 with 2 terminals (indicates temperature in the box), and another with 4 terminals or poles (this serves for motor management) in the 14AEEX engine that I imagine is yours. If so, make sure that the plug and wiring are well, the probes can be measured with polyimeter disassembling and heating them with lighter you will see their resistance, ok, if it does not varied, it is defective. As for the hot start, the 4 pole probe that does not regulate when it is hot and sends the signal as the engine is cold, putting more fuel (as if it were cold the engine), I advise you since you are, that you verify the thermostat, because in these models, the housing is plastic and they leave a lot, I already know several. I hope it helps you.
