Start problems Seat Ibiza 2002
11 years 11 months before #43986 by manual-mecanica
Start problems Seat Ibiza 2002 published by Manual-Mecanica
Hello, how do I tell you for you because I have a big problem with a Seat Ibiza 2002 ... I explain the problem the engine did not get running it and gave me 10 codes one of them was the Cam sensor the strokes I went to the engine and I started it and it does not want to start checking again with the Scaner and a half the sensor cam ´..In summary..ch Without starting the engine check synchronization of distribution ... well checking main food
11 years 11 months before #44098 by manual-mecanica
Manual-Mecanica Response on the topic Start Problems Seat Ibiza 2002
The same, does not send the injectors pulse for having a problem in the antiarranque, to see if you can check immobilizer and tell you if there is no problem with the transponder of the key, etc ... this I do not think it can be solved without the specific program of the house, you know. luck
