Volkswagen Golf
12 years 2 hours before #43851 by manual-mecanica
Volkswagen Golf published by Manual-Mecanica
Good afternoon a query. Someone knows what could be the problem that the Volkswagen Golf vehicle year 98, having good compression, new injectors and the rectified butt. I can't start and anything.
11 years 11 months before #43889 by manual-mecanica
Manual-Mecanica Response on the Volkswagen Golf
It will depend on many things like the spark, if the spark is not long and blue it does not run or it can be badly left, or does not inject, you will have to check more to be able to get out of doubt and help you better, check well if there is injection and if there is a spark.
11 years 11 months before #43954 by manual-mecanica
Hello, but is diesel or gasoline? If it is diesel as I imagine you will have to make sure that the distribution has been well left and you have to take into account that once the distribution is mounted, the injection pump allows you to adjust it some degrees loosening three screws on the side of the pulley under the pulley (which can be worked with them without disassembling) and another screw on the opposite side.
Also make sure fuel arrives at the injectors releasing the hills a bit.
All the best
