Nissan V16 (Tsuru) Without spark, without pulses
11 years 9 months before #43844 by manual-mecanica
Hello.
From a while to another the Nissan went out and does not turn on. There is no spark or pulses in the injectors. It was revoked, comb pump and pressure OK, fuses and relay ok, 12v and earth in the distributor and ok, the complete distributor is changed and remains the same. Some will have the electrical diagram to revive connections in ECU or some idea of ​​failure
11 years 9 months before #43845 by manual-mecanica
You do not block the Ecu in vola, or died, Checala
11 years 9 months before #43850 by manual-mecanica
Hi Kikemec, reviving the ECU with the naked eye, nothing strange is seen, Wuaa that can be happening. I will continue to investigate the cable branch this intact is not intervened.
11 years 9 months before #43856 by manual-mecanica
I need to know what year it is and what motor it has to help you. The first thing I check before discard
11 years 9 months before #43860 by manual-mecanica
Hi Choto. NISSAN MOTOR 1.6 16V GA16DNE 2005.
The 5V of reference in TPS and ECT are. 5 cables arrive at the distributor: there are 12v food, earth or mass, 5V. The distributor is with a cam and coil sensor incorporated into it, there is feeding current in TB coil. The continuity of distributor plug cables to the ECM is OK. ECM and Earth Food OK.
