White smoke
12 years 1 month before #43840 by manual-mecanica
White smoke posted by Manual-Mecanica
Good evening, I need your help. I have a 2004 Toyota Prado SUV. The engine was recently rebuilt, and its compression is excellent at 440 psi. It's a 1KZ-TE engine. The problem is that when it warms up, white smoke starts coming out of the exhaust, and it smells strongly of unburned diesel. It's painful to look at. I was hoping you could offer some guidance. I would be very grateful. Note: This engine is a turbo intercooler.
12 years 3 weeks before #44086 by manual-mecanica
Manual-mechanics response on the topic of White smoke
Hi, it seems to me that the injection pump might be incorrectly timed, or perhaps the timing chain is incorrectly timed. Check the timing marks and verify the injection pump timing; I can't think of anything else right now. Good luck.
12 years 2 weeks before #44198 by manual-mecanica
Hi Jamosa.
In addition to what Ismael said, check if the water level drops. It could be that the turbo cooler is leaking, or there might be water passing through one of the cylinders. The itchy eyes are due to the poor combustion causing the problem. Good luck,
Miguel
12 years 2 weeks before #44199 by manual-mecanica
Look at me that it is an injector draining that it is not pulverizing
