Pole Classic Diesel
12 years 2 days before #43824 by manual-mecanica
Pole Classic Diesel published by Manual-Mecanica
Hello, I have a problem, when I accelerate my car at 2500 rpm,
the oil witness begins to flash and an alarm sounds.- Probe with the disconnected bulbs and has an oil manometro which indicates normal pressure.- If someone knows that it can be please I wait for your answer.- Thank you.-
11 years 11 months before #44087 by manual-mecanica
Manual-Mecanica response on the polo classic diesel
Hi Fernando, look, at me in pole 1.4 I started like that, the board disassembles the alarm, and I have like that since 2002, it cancels the oil light, and ca problems ... Forget yourself, say it is a switchboard defect, ta ta ta ... and that you have to change it and po po ... I have not had any pressure problem, I have measured it and it remains the same as when I started, when I started, when I started, when I started, I Pressure that is in cylinder head, nothing happens, what VW wants to get your wool and.
