Muest noise
12 years 2 days before #43816 by manual-mecanica
NOISE AT POINT PUBLISHED BY MANUAL-MECANICA
I have an Ibiza 1.4 gasoline from 95 and a couple of days ago it makes me noise like a buzzing with the engine running but at the dead point and when the clutch pedal is removed, the noise is removed and when I let go it returns and with the car it also circulates it also does so it is only removed when the clutch floor, someone could tell me where the noise can be if the clutch bearing or of the steps of the change. The noise, thanks.
12 years 2 days before #43819 by manual-mecanica
Manual-Mecanica Response On the NOISE IN POINT
Almost always when the noise is permanent and disappears when you step on the clutch pedal the noise tries from the gearbox, then it can be pilot axis or bearings of it, if it passes when you paste softly without completely completely the pedal can then be the fault of the rolling of thrust or of the orquit that is a little past.
11 years 11 months before #43864 by manual-mecanica
I estimate friend you have to check your clutch or make your mechanic check the clutch apparently already the bearing (necklace) is already damaged and it will be necessary to change
11 years 11 months before #44114 by manual-mecanica
What they mentioned above is correct more without Czech enambio that does not lack oil to transmission.
11 years 10 months before #44210 by manual-mecanica
Hi, friend. What they mention above are valid possibilities. But you could also try the direct roller of the box. Keep in mind that while the primary axis is underway with the engine, including the direct of the box they turn in relation to the engine RPM.
Another thing you could try is to add an additive to the oil from the box (some transmission molicote)
I hope my suggestions serve you. Greetings. Successes.
