GUAYA GUAYA DEL TRACUE MATIZ GUAYA 2001
12 years 3 days before #43808 by manual-mecanica
Problem graduation of the 2001 nuance clutch published by Manual-Mecanica
Greetings I am new in the forum I am from Venezuela.
I have a problem with my nuance 2001, a few days ago driving a small metallic noise and then the clutch reminds himself when he saw the guaya was in poor condition. Buy one and install it, but now it does not take graduation, previously the vehicle did the same and only the Guaya graduate and this time it does not take graduation is as if the guaya was very long, however the arm of the clutch of the box is returned well, I do not know if it was that the arm of the box was run of its position and I have to loosen the tornillo that squeezes it (if it can be aid.
12 years 3 days before #43810 by manual-mecanica
Manual-Mecanica Response on the problem Graduation Guaya Del Trust Matiz 2001
Be careful you have a problem with the bridge or pedaling is where the pedals go, you have to change it is broken or folded, you can accidental repair it or change it is urgent
12 years 3 days before #43815 by manual-mecanica
I forgot to me can be the pedal bushing for wear
