Yundai Santamo Non Araca
12 years 1 week before - 12 years 1 week before #43770 by manual-mecanica
Yundai Santamo Non Araca published by Manual-Mecanica
Hello good, my consultation is the following I have a hringay Santamo the problem is that part but after barias games later I do not change the relay that are going under the glove compartment that go next to the Ecu because they failed but more of that does not please a help since my lady occupies her suede. Thank you very much thank you very much
Latest edition: 12 years 1 week before by .
12 years 6 days before #43775 by manual-mecanica
Manual-Mecanica Response on the yundai Santamo no Araca
First of all you will have to check that it lacks when it does not start if it is a spark, fuel or compression, it is not always as simple as a fuse or relays, which is why we need more information in the case.
12 years 6 days before #43776 by manual-mecanica
Thank you for answering good when I do not part I give it with the spark plug cable and jump spark, I changed the benzine pump thinking that it was little precion, it comes good Revolutions is 800 and Avesses is in 2000? Will something to do with? I would miss checking the chassis and motor lands and the last case review the plugs of each module is very rare mind, I would appreciate if you had another suggestion for your attention thank you
12 years 6 days before #43778 by manual-mecanica
scheme if you have compression and spark what should be missing would be fuel that for some reason does not inject if you have a difficult spark that is the captor. When you do not want to start fuel beachable by the Amision and Test, with respect to the revolutions if it can be lands, but how is the battery? Peugeot passes
