Accord 95
12 years 1 week before #43729 by manual-mecanica
ACCORD 95 Published by Manual-Mecanica
Good afternoon I have an action that when lighting in cold turns on a wonderful but when we go to its manageability temperature, I keep it on if I keep it accelerating it, it is worth mentioning that I just changed the bands of time and repair the heads thus replacing all the stamps. that could be and read on a relay main and also I doubt the IAC valve.
12 years 1 week before #43732 by manual-mecanica
Manual-Mecanica Answer on the ACORD 95
It could be the temperature sensor that goes to ECU that causes the failure to the IAC or could be the minimum engine.
12 years 1 week before #43747 by manual-mecanica
If you could indeed have problems with the temperature sensor, but the VALVA IAC could also have some fault to clean it first to see if it improves, because if you keep it accelerated and it works, it can happen that the revolutions fall a lot, in which number of revolutions is it?
