Ignition problem Daewwo Cielo 98
12 years 1 week before #43705 by manual-mecanica
Ignition problem Daewwo Cielo 98 Published by Manual-Mecanica
Good I have a sky daewoo and does not want to check the coil and spark plug cables and arrives current, the bomb lights but when I give it a Aranque it seems that it was drowned (I also clean the injectors) I do not know what to do what to do
12 years 1 week before #43720 by manual-mecanica
Manual-Mecanica Response on the Idea Daewwo Cielo 98
How is the compression of the vehicle? The spark plugs come wet? The tuning is this ok?
12 years 1 week before #43735 by manual-mecanica
What you can do is remove fuel hoses and start to see if Gasolina arrives could be an obstruction in one of the hoses the other is that you should check all the fuses as a procedure.
