Spark problem in Volkswagen Golf Manhattan
11 years 9 months before #43782 by manual-mecanica
Manual-Mecanica Answer on the spark problem in Volkswagen Golf Manhattan
As you have told you, the normal thing is from the hall of theco, but there is also a very salao, taquimetric
11 years 9 months before #43811 by manual-mecanica
If the immobilizer system was bad the car would not start.
I would check the fuel pump, if it were in the correct state, it would check the distributor and the cables that are arriving current.
11 years 9 months before #43812 by manual-mecanica
It is true to check the relay that the partner has said, that happened to me in an Ibia of 99, and it was the rel.
He started and sometimes stopped.
11 years 8 months before #44129 by manual-mecanica
Hello, the vw golf started as I have then turned off and it does not start, the problem is that I have the spark signal signs, very good compression, but it does not start verify the synchronization marks and they are correct, if they can help me with the order of ignition. On is new, the rotor is acceptable, the candles are new. I await your help.
Thank you
11 years 8 months before #44165 by manual-mecanica
Hello, check with spark plug, if you throw spark when you turn, I do not think you have the changing cables of order, I would not have torn you, try to measure the high coil cable, but I repeat, verify the tachytric relay, luck
