Spark problem in Volkswagen Golf Manhattan
11 years 9 months before #43688 by manual-mecanica
Spark problem in Volkswagen Golf Manhattan published by Manual-Mecanica
Hello, how are you friends. I hope you can help me.
My problem is with a Volkswagen car I do not have a spark, it is to check the ECU and everything is in order, the pulse of the distributor if it is but in the line of the coil it is cut at the time of the boot. Nor have I pulse for the fuel pump.
Thank you
11 years 9 months before #43690 by manual-mecanica
Manual-Mecanica Answer on the spark problem in Volkswagen Golf Manhattan
Check the distributor that does not have a game on the axis and controls the hall sensor that goes in it, if there is rubbing the signal is lost, tell us how you go, cordial greetings. : Laugh:
11 years 9 months before #43699 by manual-mecanica
Thanks for the answer. Having a solution I will tell you thanks
11 years 9 months before #43715 by manual-mecanica
If you have immobilizer, make sure that it works correctly. I have understood at the time of starting the car starts and stops in no time
11 years 9 months before #43721 by manual-mecanica
The spark does not pass through the ECU, only distributor and hall sensor, in the Volkswagen it tends to happen that this intermittent failure sensor passes a lot, I think it goes there but it regulates that you also have a coil and a module of teaching that go together, that it also fails but the fault is different the spark is but it is very weakened and the compression goes out. But if you do not have the bomb either then the problem could go through the immobilizer also you want to have two problems, failure to reopend or after washing it?
