BKD 2.0tdi engine tightening and connecting rods
12 years 1 week before #43683 by manual-mecanica
BKD 2.0TDI bench and rod tightenings published by Manual-Mecanica
Hello good morning, the fact is that I have an Audi A3 8p with BKD engine, the car was left without oil pressure, and as it is general, I was left without lubricant in the rod and bench bushings and I need to know that tightening pairs carries, I am not very expert in the subject, and I would also want
12 years 1 week before #43685 by manual-mecanica
Manual-Mecanica response on the tightening and connecting theme BKD 2.0tdi engine
[IMG
Uploaded with Imageshack.us
12 years 1 week before #43686 by manual-mecanica
Or you ran out of oil or the pump is wrong. The cylinders check them, all crankshaft caps and changing cams, butts, seal and lucky the turbo will be fine.
Remember that cylinder heads are loosen in a spiral or cross very gradually the time to press the same.
I hope the photo serves you.
