OBD2 failure, P0705 Failure Code
12 years 3 months before #42661 by manual-mecanica
Manual-Mecanica response on the OBD2 failure, Failure Code P0705
CODE: P0705 MAKE: Generic
Description: Transmission Range Sensor Circuit Malfunction (PRNDL INPUT)
Notes:
I hope it is useful
12 years 2 weeks before #43676 by manual-mecanica
Thanks friends, the failure was already a collector -like sensor that goes where the barilla that goes from the lever to the gearbox, the electrical connectors had burst and that was the fault although the engine worked normal only by the check Engine
