OBD2 failure, P0705 Failure Code
12 years 1 month before #42421 by manual-mecanica
OBD2 failure, P0705 Failure Code published by Manual-Mecanica
Hello friends, I can help me I have a fault in a Nissan 200Sx year 1997, ga engine, mechanical speed box and the check on with the P0705 fault that is I believe it is the failure of an automatic box and erase it but after 2 days of use again the check is activated again I have 5 years of use and I had not given me this fault any help please please the mail
12 years 1 month before #42435 by manual-mecanica
Manual-Mecanica response on the OBD2 failure, Failure Code P0705
Does your car have a limiter? <-I mean that from a button you can mark a speed and there is no happens or you whistle if you pass. ???
Or cruise speed or what is it called? <-What you marks on the 95 kmh/mile road, you lift your foot from the pedal and stay at that speed.
If you try to see if it works that sometimes you put on those things and give you the automatic cash failure even if you do not have.
12 years 1 month before #42446 by manual-mecanica
Thank you friend if you have crousero or cruise control speed and I don't know if it actually activates by mistake but I already have the idea where the failure can walk with this that I think I thought it could be a computer error
12 years 2 weeks before #42657 by manual-mecanica
P0705 Storm range sensor =>-F125
fault in the electrical circuit
12 years 2 weeks before #42660 by manual-mecanica
Here I leave a link for the OBD2 codes of all brands.
Link: www.obd-2-codes.com/
Greetings.
