THERMOSTAT
12 years 6 months before #42037 by manual-mecanica
Thermostat published by Manual-Mecanica
: Silly: Hello friends, someone can help me: Silly: a problem in BMW 740 year 1997 I do not circulate the water, it does not open thermostat valve this good is good, does the radiator have no temperature sensors that will be that? Ho there is another way to circulate water
thanksssssss
12 years 6 months before #42041 by manual-mecanica
Manual-Mecanica Response on the thermostat
wave removes the thermostat and place it in boiling water and observe whether the spring is compressed, or check the water pump that is good
12 years 6 months before #42045 by manual-mecanica
The water synchracion is very easy water pump and thermostat, there is no more, it is everything there is, check these components and warn.
12 years 6 months before #42046 by manual-mecanica
Hello thank you for attending to milamado, is what you tell me and everything ok is, the water still does not circulate, will it be the temperature sensir ???
12 years 6 months before #42047 by manual-mecanica
