The RPM in Ready Grand Vitara goes down
12 years 5 months before #41931 by manual-mecanica
RPM lows in Ready Grand Vitara published by Manual-Mecanica
Estimated
I have a Grand Vitara year 2000 displacement 2.0
When the game starts and lower the RMP as it is maintained for a long time, until it reaches 1000 rpm and there it is going up and down.
This did not happen before ...
you can help me with this topic
12 years 4 months before #41972 by manual-mecanica
Manual-Mecanica response on the subject lower RPM in Ready Grand Vitara
The first thing is the first thing, the Relay regulator is checked, clean it and clean the admission body and see how it is, if you do not well check that work all the cylinders and that no coil fails, but usually it is the problem of the first only dirt, unless they disconnected the battery for some repair if it was so it is missing regulation and memory nothing else
11 years 9 months before #45291 by manual-mecanica
Friend I disconnected the battery and now I have the RPM low, how do I make that regulation and memory that you mentioned?
Greetings and grateful in advance.
