Solve Tracera Light Failure in Cherokee
17 years 4 months before #3900 by manual-mecanica
Solve Tracera Light Failure in Cherokee published by Manual-Mecanica
Greetings ... I have a problem with the Cherokee, I change the light bulbs from the original mopar bulbs and continue to show me the message of \ "tracera light failure \" All bulbs turn well on, as I do to remove the message. Thank you.B)
17 years 4 months before #3917 by manual-mecanica
Manual-Mecanica Response on the Re: Solve Light Failure Tracera in Cherokee
Check those of the enrollment and check the watt of the bulbs, it may be that you have put any with the wrong vatia heard, if everything is fine check the ground cables.-
