Change Heater Renault Express 1.9
12 years 2 months before #41789 by manual-mecanica
Manual-Mecanica Response on the topic Change HEATERS RENAULT EXPRESS 1.9
Good afternoon
to see if it is explained
is white smoke or water vapor?
How do you know when an engine is heated and the stops absorbs moisture of the environment?
Well, the same thing happens to the exhaust pipe
in the catalyst, anti -dating silencer, etc. It accumulates moisture and when you start the cold engine, heat it and release white smoke that is actually water vapor
ever seen a gasoline engine when starting cold that releases water drops by the exhaust?
same what
steamy
is my humble opinion of course
the same other partner will guide you better but I would not worry about
pd: all this roll is based on the fact that before changing the heating do not do it and that this distribution is set up
a greeting and forgives the talk the talk
