Citroen C3 HFX does not start in cold
12 years 5 months before #41630 by manual-mecanica
Citroen C3 HFX does not start in cold published by Manual-Mecanica
Greetings Boys I have a doubt about the start of this in cold, how can I deceive the ECU to rise from revolutions at the start as if the cold engine was?
: Cheer: And expected with some coxes to disconnect the refrigerant liquid temperature sensor to see if when starting it is accelerated as at low temperature and I think it enters into failure and jump the radiator electro -ventilators (I imagine that the admission temperature sensor does not accompany and the Ecu Ace Acts like this and enters into emergency mode)
: HUH: if I disconnect the admission temperature sensor, act the supercharger for the aid for the starter. in cold, falsifying the signal of this to the Ecu?, (as simple as cutting a cable and trying, but before, I would like to read your opinions).
It starts badly and I always have to step on the cold accelerator a little, then hot, the fucking: Laugh: : Laugh: : Laugh: hehehexee
a health is well and thank you very much to everyone;)
12 years 5 months before #41639 by manual-mecanica
Manual-Mecanica response on the topic Citroen C3 HFX does not start in cold
Your car has a failure, the Relay actuator does not work.
In cold a small tetoncete that is found in the butterfly body goes out and leaves you the car a little accelerated, when it breaks it is not accelerating and that is why it is your turn to step on it to start well. <-If it is gasoline).
If it's Diesel I don't remember how it is going but it's such a subject.
12 years 5 months before #41641 by manual-mecanica
Well if not, I doubt. To deceive the NTC (air temperature sensor) you have to put a resistance in one of the cables of 0.001 omios or little more to alter the voltage value and deceive the UCE.
Points to take into account: When the car is hot, it may be that they are won by power horses or that behaves like the ass, everything is to try hehehe.: Laugh:
12 years 5 months before #41644 by manual-mecanica
Manual-Mecanica response on the Citroen C3 HFX 1.1 topic does not start in cold
Igryo thank you very much for your fast answer, see if I get a little while and I'm going to get down to work and I tell you,: Cheer: I feel proud that I have some idea, and thanks to your help too.
I already tell you.;)
Greetings and thank you all
12 years 5 months before - 12 years 5 months before #41645 by manual-mecanica
By the way I hope I don't behave like the ass and that horses wins: Laugh: : Silly: : Silly: my mother kills me: blush:
Latest edition: 12 years 5 months before by .
