Greetings Boys I have a doubt about the start of this in cold, how can I deceive the ECU to rise from revolutions at the start as if the cold engine was?
 And expected with some coxes to disconnect the refrigerant liquid temperature sensor to see if when starting it is accelerated as at low temperature and I think it enters into failure and jump the radiator electro -ventilators (I imagine that the admission temperature sensor does not accompany and the Ecu Ace Acts like this and enters into emergency mode)
 if I disconnect the admission temperature sensor, act the supercharger for the aid for the starter. in cold, falsifying the signal of this to the Ecu?, (as simple as cutting a cable and trying, but before, I would like to read your opinions).
 It starts badly and I always have to step on the cold accelerator a little, then hot, the fucking
 hehehexee
 a health is well and thank you very much to everyone
