The engine starts but stops and regulating
12 years 3 months before #41571 by manual-mecanica
Manual-Mecanica response on the subject The motor starts but stops and regulating
If you refer to the electronic ignition of the engine if it has and works as I told you before it starts but the guacho is not regulating and stops
12 years 3 months before #41593 by manual-mecanica
The electronic Starter is a needle that only works in Relay but I think your vehicle does not bring this carburado or you still do not.
12 years 3 months before #41595 by manual-mecanica
Well, check the Admission collector's board and carburetor
12 years 3 months before #41604 by manual-mecanica
Hi Renault 11,
discarding the classic, that is:
stitching, spark plug cables, carburetor measures, carburetor steps (gum) carburetor cleaning, floating level, gasoline pump. That is all this ok.
It makes a fast test, disconnect the escape before the silencer and probate it, if it works normal you have the covered silencer.
Notice how it went with the test.
Greetings
