DISTRIBUTION TENSOR CITROEN C3 1.1 HFX
12 years 6 months before #41511 by manual-mecanica
DISTRIBUTION TENSOR CITROEN C3 1.1 HFX Published by Manual-Mecanica
Greetings to all:
And tried to change the distribution to this coxe but I do not know very well how the tensioner is going, I am oriented with the self -destroying and I have done it as it says "or so I think" and the Coxe does not start except with help stepping on the accelerator a little; When starting the Coxe rounded well I do not hear rare noises I am scared because I try ahead and then delaying a dandelion of the crankshaft but I do not hear strange noises and in one of the tests I started well but I kept seeing the weaning belt between crankshaft and camshaft; It can influence the battery decrease for so many start tests although it appears to me that the starter engine drags well; I have two days to stop with him and I am losing encouragement and forces in addition to scares in case something else is damaged.
Do not save how much I appreciate your help with this problem.
I attend Telephone or Wassap 677811538.
As always a health and thank you very much.
12 years 6 months before #41533 by manual-mecanica
Manual-Mecanica Response on the Tensioner Distribution Citroen C3 1.1 HFX
Is your question how the tensioner is put? It is the potato looks, the tip that is alone is the indicator of see Hollito you put the drill and it is locked and you all put the drill then you finish the tensioning with the corresponding Allen key and when you are ready, press the nut and now.
