Chevrolet 8.1 accelerator body
12 years 6 months before #41424 by manual-mecanica
Chevrolet 8.1 accelerator body published by Manual-Mecanica
Greetings I have a problem with the 8.1 engine body stops accelerating, the accelerator body is changed and the same and I do not find the antifreeze bulvic can tell me where it is located
12 years 6 months before #41451 by manual-mecanica
Manual-Mecanica response on the topic of Chevrolet Accelerator 8.1
Temperature bulb, it is the one that operates the electrventillator, the temperature sensor is found in the cylinder head or in the body of water, but you should check the pedal sensor if it brings it,
