Trapezio Peugot Parnet
12 years 3 months before #41355 by manual-mecanica
TRAPEZIO PEUGOT PARNET Published by Manual-Mecanica
Hello friends,
today I have passed the ITV and they have lying me unfavorable with some recording defects. Brake Luz with little light and things like that.
The most grab is fixing (posterior) fixing of the right front trapeze.
I am not a mechanic but when you have no job and you are bad money and if you like mechanics and you have time as in my case.
Well, I would like some of you who will know more than mechanics, give me some councils, how to do it would be appreciated.
12 years 3 months before #41382 by manual-mecanica
Manual-Mecanica Response on the Toppezio Peugot Parnet
I would help you but I don't know what they refer to with trapeze, here in Chile that term is not used, I know well the parnet that is the same as the berlingo, if you tell me where it goes or what does it help you without problems
12 years 3 months before #41401 by manual-mecanica
The trapeze is the piece that holds the hose, in the hose goes the brake disc and above the hose as shock absorber.
What you have bad is a rubber that goes from the chassis to El Trapecio.
They call it Trapecio because it has a trapeze shape, suspension arm would also be.
12 years 3 months before #41409 by manual-mecanica
Haaaaaaaaaa the suspension tray, now if I plug, if it is usually true the rubber bushings, but you have to check the fixing bolt, the fixing bolt can be loose, anyway it is more comfortable and quick to change the tray Biene complete with rotation and everything, I warn you in advance, which is a bit hard to take it out but want to let go, you can let go of the damping. Address and fastening of the newspaper, it is only force nothing more or anything the direction terminal is sued from the dough does not rotate.
12 years 3 months before #41410 by manual-mecanica
