Injection problems with Nissan Frontier ZD30
12 years 6 months before #41249 by manual-mecanica
Injection problems with Nissan Frontier ZD30 published by Manual-Mecanica
I have a problem with the electrical system of the injection pump does not distribute the diesel to the injectors and it does not give way to the return pipe of the same and replace the injection pump and the problem you perceived
12 years 6 months before #41252 by manual-mecanica
Manual-Mecanica Response on the subject Injection problems with Nissan Frontier ZD30
Check the signal to the pump solenoid if it does not arrive, it does not arrive control module and part from this point to locate the cause.
12 years 6 months before #41254 by manual-mecanica
Check the signals of the EDC module connector (the one on the pump) the problem can be in the ECU (electronic control unit)
