I need urgent help
12 years 8 months before - 12 years 8 months before #41223 by manual-mecanica
I need urgent help. Posted by manual-mecanica
I have a 1996 Blazer...the problem is it won't start. I already replaced the fuel pump and nothing changed. I scanned it and it didn't show any codes. If I add a little gas, it starts but only for a moment. I've checked for fuel pulses and they are there. I've checked the connectors, fuses, distributor power, and coil, and there is power. I hope you can help me...it's a 4.3 Vortec engine. If anyone has the computer diagram and could share it with me...thanks.
12 years 8 months before #41238 by manual-mecanica
Manual-mechanics response on the topic: I need urgent help
Of
12 years 8 months before #41239 by manual-mecanica
Did you check the electrical part of the ignition switch? It might only be sending power to the starter motor, but cutting off the current when you release the key.
12 years 8 months before #41244 by manual-mecanica
if all this has already been checked
12 years 8 months before #41245 by manual-mecanica
of the computer
