Seat Ibiza starter [solved]
12 years 7 months before - 12 years 5 months before #41118 by manual-mecanica
Start Motor Seat Ibiza [Solved] Published by Manual-Mecanica
Hi there!! This vehicle has been stopped as a year and a half.
As you have no battery, I put the tweezers and try to start it and only one click when the key and another click when it stops acting, thinking that the serious breakdown would take it out, but check it and outside the vehicle the starter engine works perfectly, so check that it will reach all the cables and all the cables are well fed.
Would anyone tell me why it doesn't work? And what can I do?
Thanks beforehand. Greetings!!
Latest edition: 12 years 5 months before by .
12 years 7 months before #41122 by manual-mecanica
Manual-Mecanica response on the Seat Ibiza starter
Try it with a battery with no cables, because you need that the Earth is very good, if nothing happens, although I think, turn the engine by hand to rule out that it is brought
12 years 7 months before #41139 by manual-mecanica
The click is from the Bendix that has the starter engine, is an axis with a gear that causes it to come out and gear to the crown of the inertia steering That it is better to gain it, look at the pendix and roll the gear, I hope to be helpful, a greeting !!!
12 years 7 months before #41140 by manual-mecanica
The click is from the Bendix that has the starter engine, is an axis with a gear that causes it to come out and gear to the crown of the inertia steering The battery, which is better than pinciring it, looks out that the pendix comes out and is the gear, I hope to be helpful, a greeting !!!
12 years 6 months before #41147 by manual-mecanica
I'll try a new Aver battery, but I turned around with my hand and at the beginning a bit hard it went but we already gave him several and it seemed that something better but even and everything could not move it so I would buy a battery today and I hope I hope you are lucky.
Thank you very much for your help !! I will tell you if I can start it or not.
Greetings!!
