Good,
 first of all, that it is clear that I am not a mechanic, not even an amateur.
 I go to this forum to ask you a problem, to see if someone can tell me what the hell happens to my car. I will try to be as clear as possible.
 I have a Hyundai Accent Gls for 3 years (I already had 6 when I bought it). It has about 120,000 km and uses gasoline 95.
 The problem is the following:
 from time to time I jump the chivato of the engine intermittently, flashes for a time (like 1 minute), it goes out, after a while again flashes, it goes out ... and so on. When this happens I notice that when you step on the accelerator the car does not throw. If I stop at a traffic light, the engine is threatening to stop, the recruption needle lows almost zero and goes back to 800 or 900. I also notice a smell like exhaust gases. Note: The alternator and spark plugs are new.
 And here comes the weirdo: it only happens when the tank fills and I walk about 80km. That is, the deposit full, at 80-100 km the problem appears, and from the fact that the gas level reaches 3/4 of the deposit (more or less) does not do it again. I realized this for a long time and although it seemed like a asshole I started to fill always half a deposit or a little more, but never butt, and from time to time I threw it up. Well, whenever he filled it halfway, he went like silk and every time he filled him to the top, the problem appeared (at least 4 times). I know it is weird and that it seems that it has neither feet nor head but I am not inventing anything. The problem is as I tell you.
 Well nothing, I hope someone can give me some explanation ... as I will continue to fill the deposit halfway!
 Greetings to all
