Touran 2009 1.4 fsi problems
12 years 7 months before #40928 by manual-mecanica
Problems Start Touran 2009 1.4 FSI published by Manual-Mecanica
:( I have made several changes or a small maintenance where I change all the filters of the car, in addition to the 4 spark
plug
12 years 7 months before #40933 by manual-mecanica
Manual-Mecanica Answer on the topic Problems Touran Touran 2009 1.4 FSI
Hello Cuban_al_agua.
No engine dies like this, without more or more, in order to collaborate, data are missing: you do not tell us if the engine revolves when it will start, if you do not do it you must verify that it does rotate manually, that the starter is good, if there is movement of the valves, you do not say that engine is, or if it is gasoline or diesel, it would have to verify spark or injection. Support us from that data and we can help in something.
Miguel
12 years 7 months before #40937 by manual-mecanica
It is true missing information and you must also pay a little more attention or care in the info since when saying it does not start, depending on the country that is the forista varies a little, it does not start is that the vehicle does not start up or it may not be that it does not start Jajaj is a common problem that happens to us here
12 years 7 months before #40953 by manual-mecanica
Hello everyone,
well answering your questions, I will tell them that if the starter engine works and turn the engine, it is a 1.4 FSI gasoline engine,
can any tooth of the distribution chain of this engine model skip? since I have that doubt
12 years 7 months before #40959 by manual-mecanica
In vehicles with chain it is very, very difficult for their teeth to jump, but not impossible, of course if the teeth are skipped in vehicles with chain, the vehicle is very bad, the vehicle puts an atrocious noise and they do not walk well, but if it were on the outside
