Great Vitara XL5
12 years 9 months before #40829 by manual-mecanica
Grand Vitara XL5 Published by manual-mecanica
I have a large XL5 or XL7 6V vitar
12 years 9 months before #40866 by manual-mecanica
Manual-mechanics response on the topic of Grand Vitara XL5
Hi, these cars usually have an idle air control valve. If that's what's faulty, which from the limited information it probably is, replacing it will fix the problem. Replace it; a diagnostic scan will confirm this. Cheers!
12 years 9 months before #40874 by manual-mecanica
Hello, greetings. Before you decide to replace it, you can try cleaning the IAC valve. If you still have the same problem afterward, then you can replace it. You didn't mention if the engine just stalls or if it's accompanied by excessive black smoke, which would be another issue.
I hope it's just a problem with the idle speed being adjusted incorrectly.
The IAC valve is located next to the throttle body, usually held in place with two Torx screws.
Use thinner to clean the tip and stem, as well as the seat inside its base
. Good luck.
12 years 8 months before #41141 by manual-mecanica
Take already !!!! You do know how to give the answer !! , the truth is that I am new here even if it had been registered, I did not connect now I am taking the vice and little by little the truquillo, a greeting
