I have problems with my automatic v16 year 94
12 years 9 months before #40746 by manual-mecanica
I have problems with my automatic V16 year 94 published by Manual-Mecanica
Hello friends, I address you for the following problem, what happens that I have a Nisan V16 Super Automatic SALON YEAR 94, what happens to me is that when I make it work the release does how it stops and then it continues to work and so on succession and I have to accelerate it so that I do not do that, and just as when I stop in a traffic light or in any stop and even the engine stops , I change benzine pump, spark plug cable, oil and fuel filter, spark plugs, air filter but it remains the same, and I don't know what can be if they can help me, I appreciate them Yasi, take it to the mechanic with the real problem and not more than more thanks I wait for your response.
12 years 9 months before #40878 by manual-mecanica
Manual-Mecanica Answer on the subject I have problems with my Automatic Nisan V16 year 94
Hello friend, I recommend that you verify the additional AIC valve, this valve is responsible for supplying air in relief and prevents the engine from stopping.
When these inconveniences are usually manifested, I attach the manual.
Steps to follow:
1 Locate Valve
2 Remove it (carries 2 screws)
3 Extract it carefully (do not turn or sink the stem that will see the valve once removed)
4 Apply clean contact (electrical contact cleaner)
5 Wait that the liquid dries and continues to INTALAR.
