Hi Nesecito helps
12 years 8 months before #40693 by manual-mecanica
Hi Nesecito Help Published by Manual-Mecanica
Good morning I am new on this page and I am requesting help with a mechanical problem of a Mitsubishi Montero V6 Gasolina, the problem is that it has been done a repair has been reviewed the order of ignition of the distributor, this car turns on but does not have the strength to advance if someone can make any suggestion I appreciate it.
12 years 8 months before #40694 by manual-mecanica
Manual-Mecanica Answer on the subject Hello Nesecito Help
If you have touched the distributor, and the only consequence is lack of strength .... The safest thing is that it is not well tied.
12 years 8 months before #40698 by manual-mecanica
The issue that I present is common in this type of engine you have to take into account the order ignition because the tower of the high cable you see on the outside, inside the lid is a maze, always happens that they are cable cables. If you already did this verification and the problem persists, try to advance the time of ignition. I hope to have helped you.
12 years 8 months before #40704 by manual-mecanica
Hello, I appreciate the help received, I would also like to rule out, if any air sensor can affect I see loose cables near something that can be a sensor in the admission manifold.
I thank again for the tension provided.
12 years 8 months before #40706 by manual-mecanica
Hello, do you mean the advance in the distributor or time in the chain?
