Ford Focus Endura 1.8 Tddi
12 years 9 months before #40617 by manual-mecanica
Ford Focus Endura 1.8 TDDI published by Manual-Mecanica
Ola Good afternoon, I am crazy looking for and I don't find the problem. Aber turns out that my car is emptied of water deposit and does not know where it throws it, because water is not seen on the ground. It is jumping the fan when it reaches 90 degrees and start emptying the deposit. Where is watering ??? In case someone answers me, in the oil it has no water, that if, through the exhaust tube it throws white smoke as steam. Could it be that you have any duct of the heating attached to the exhaust pipe ??? I don't know but I'm crazy and I don't find the breakdown. Please help. Thank you very much and greetings
12 years 9 months before #40618 by manual-mecanica
Manual-Mecanica Response on the Ford Focus Endura 1.8 TDDI
Hello, how, the car starts, if it starts failing it is because the water is put to the cylinders, you can have some water loss that it only loses when walking, such as the water pump or the heating radiator, you could try, taking out the injectors and see if by any long water cylinder, if you do not have any loss that evaporates when walking, I hope you serve you and tell you any more.
12 years 9 months before #40619 by manual-mecanica
Oh tell me how it starts in cold if it fails it is because the water is put in a cylinder, there could be the Board or Rota cylinder cover
12 years 9 months before #40620 by manual-mecanica
I knew you would tell me that. I tell you that the Board is not because the oil is perfect, by the water pump does not pull xq no water is seen or drip and inside the abitaculus neither do there a water. You can not heat the car. The car starts perfect in cold. It is to open the thermostat and jump the fan and you can open the tank plug and see perfectly how the level is lowering. It's incredible and I don't know where that water is. More opinions x favor. Thank you very much to the previous opinions, I appreciate it
12 years 9 months before #40628 by manual-mecanica
If you say that you throw steam for the escape then you have the broken tápa. On the other hand there is not much to look for. If you throw steam, joint, tápa. If the water goes down, look for there, if those are the data that you give me and you already reviewed everything
