Inverted polarity
12 years 8 months before #40494 by manual-mecanica
Inverted polarity published by Manual-Mecanica
Hello. I call Ramon I am new in this ... I have a problem with a 4T motorcycle that the current is changed to me, that is, it is positive for the mass cable and the negative for the current ... does anyone know anything about this ???? thank you...
12 years 8 months before #40526 by manual-mecanica
Manual-Mecanica response on the subject inverted polarity
I tell you the vehicles manufactured for some countries (England) use + by the chassis and others (Europe) - by the chassis. Another thing is that you have the battery with -For the chassis and in some component or cable you are crossed by fault.
If it is Averia, follow the cable other than the chassis and check with polyimetter at several points to get the fault.
