I am installing hydrogen cells but I have
17 years 3 months before - 17 years 3 months before #3834 by manual-mecanica
I am installing hydrogen cells but I have published by manual-mecanica
I have problems with the oxygen sensor how can I deceive the computer that advise me
Last edition: 17 years 3 months before by .
16 years 5 months before #7971 by manual-mecanica
Manual-Mecanica response on the Re: I am installing hydrogen cells but I have
Hi Jean Carlo, tell me what happened to the cells I am doing one for my Niva 1600 car and I have doubts about how many sheets I must assemble and how is the assembly I have seen different forms but the doubt persists, I help me I have some dope on the oxygen sensors if you still need it, my sheets are 10x15 cm in 2 m/m, the box where I think the one I think about the set of 13x19 x 22 cm. 70 AMP alternator, and 90 AMP battery. The bubbling was done from a radiator water reserve container that has a double bottom and guarantees level to this I put a chek at the gas outlet. Write to With your address and if you still need the doc I send it thanks
16 years 5 months before #7983 by manual-mecanica
What do you want to do so that you want to deceive the oxygen sensor? What is the purpose, and what would be the problem if you leave it
