Clutch cable adjustment
12 years 8 months before #40409 by manual-mecanica
CLUTCH CABLE ADJUSTMENT Published by Manual-Mecanica
Good morning, I have a problem I have a 1989 golf and the clutch cable is already very hard my ask is how to do to soften when stepping on the pedal. greetings.
12 years 8 months before #40443 by manual-mecanica
Manual-Mecanica response on the topic adjustment of the clutch cable
That model carries the steel cable, it is normally dirt or that is dry, where it connects with the pedal inside the abitaculus, throw a little oil or if you can disassemble and try to fill the oil case. If Aberia is not fixed, it is because the cable is disilageting and the pieces of broken cable stuck.
Take it out if you see that you can't get the case to change it well.
12 years 8 months before #40446 by manual-mecanica
Thanks Igryo, you will have some visual aid I do not want to move and then I cannot assemble it. greetings.
12 years 8 months before #40449 by manual-mecanica
Hello friend, you should not forget that there are other causes that put the hard clutch pedal such as the view where the thrust roll loses softening of displacement and that the diaphragm of the pressure plate is becoming increasingly hard due to the changes in motor temperata clutch ... in addition to 3l cable for alleged ..... ready good luck
12 years 8 months before #40450 by manual-mecanica
You have in the Manuals area one that puts manual of repairs and settings golf, there are splices with drawings such as taking and putting the cable
