Citroen Xantia 1.9 TD
12 years 8 months before #40328 by manual-mecanica
Citroen Xantia 1.9 TD published by Manual-Mecanica
Hello everyone! See if you can help me: I have plugged the computer into the car and puts: Start Sensor Injection What happens is that not even the mechanic does not know how well where the breakdown is.
12 years 8 months before #40356 by manual-mecanica
Manual-Mecanica Answer on the Citroen Xantia 1.9 TD
It is the injector that has the black cable.
12 years 8 months before #40366 by manual-mecanica
Thank you for the answer. The problem is that the injector that the sensor has just changed and before putting the mechanic with the polyimetter and says it function well.
12 years 8 months before #40367 by manual-mecanica
Although it is good of resistance, it can have an internal mechanical problem and not generate signal, to see it I should try the oscilloscope.
12 years 8 months before #40368 by manual-mecanica
What are the symptoms presented by the car
