Hyundai Excel 93 does not start
12 years 8 months before #40317 by manual-mecanica
Hyundai Excel 93 does not start published by Manual-Mecanica
Hello everyone, I hope you can help me, the car is Hyundai Excel of 93 injected, the problem begins with a lot 12.47 volt. Do you exist any relay that originates the Averó and where is it located ???
12 years 8 months before #40318 by manual-mecanica
Manual-Mecanica Response on the Hyundai Excel 93 subject does not start
The Excel when they throw too much black smoke, the most common is that the air flow sensor fails you can disconnect it to see if there is any improvement. The TPS is very unlikely to produce that fault but the instability in the minimum march and that now it does not start it may be due to dirty spark plugs if you already tried cleaning them or changing them and yet it does not start you have to check if there is a spark and if you have it you should check if there are pulses in the injectors. If there is none of the 2 then verifies the battery and ignition voltages to the computer and the reference voltage in the TPS (5V)
12 years 8 months before #40319 by manual-mecanica
I thank you Choto, but the problem I have now is the total electrical signal, I have no electrical signal to the board so I cannot start. If you could help me please.
12 years 8 months before #40320 by manual-mecanica
You already checked the Poles Earth of the Motor and the body. Because the one who does not give you pilots is not an impediment for you to start and you are missing all Voltage feeds you have to start by checking the main fuse box.
12 years 8 months before #40321 by manual-mecanica
If Choto, check the battery I have a voltage of 12.47 volts, check the continuity of the fuses that are inside the car on the lower left side of the OK driver. That is why I ask if there is some main relay to check and where it is located.
